Hey all
I was tiped of today that the DPI Setting in Windows scales the classic client also so i set towards exploring it. And found that..
It Does Work!Here is a quick run down, (guide was made in Windows 7, it might differ slightly for WinVista and alot for WinXP)
Step 1:Attachment:
Right click desktop any where there isnt anything else. and select Screen resolution.
Step 2:Attachment:
Below display settings theres a link to make text larger or smaller, this is what affects the cc also other wise know as DPI.
If you want to use the default setting of 150% for all of windows you can skip step 3 and 4, and just select the 150% standard option.
NOTE: the 125% enhancement does not affect Classic Client in any way.Need to Log off windows and back in to take effect!!Step 3:Attachment:
Select custom DPI. if you are still reading.
Step 4:Attachment:
134% is the limit to where Classic client becomes 1.5 times it's regular size. anything less and it will be normal size.
Result:Attachment:
Hope the guide is useful for some
