View unanswered posts | View active topics It is currently 19 Sep 2026, 00:21
Did this page help you?
Yes 100%  100%  [ 1 ]
No 0%  0%  [ 0 ]
Total votes : 1
 Post subject: Plant Growing Techniques.
PostPosted: 29 Jan 2007, 16:38
I have been growing plants for a while now, and have grown some techniques i would like to share.
There are Three ways to grown plants:
  • Locked down in a house (NOT in containers)
  • In backpack, bank and beetle
  • In New Magincia in the Nature
Locked Down Method
  • They always grown on server up.
  • They will not grow on the very first serverup in thier lifespan. But will grow every one after that.
  • They can be put on top of each other.
Techniques for locked down plants:
For some types of plants you can stack up to 10 in one stack. like so:
But some plants are really tricky to open using this method, in particular poppies and campions, and the ones from peculiar seeds.
For stacking these the following method is recommended:
Explanation:
Step 1: Stack 5 bowls on top of each other, and lock them down, i normally lock one down after dropping it, but before dropping another, easier to target.
Step 2: Raise the top one, 4 times.
Step 3: Raise the 2nd from top, 3 times
Step 4: Raise the middle one, 2 times.
Step 5: Raise the Second Lowest, 1 time.
Using your: Deco Tool Image
This makes them ALOT easier to open once they bloom especially like previously mentioned for campions and poppies.
Backpack Method
  • They grow on next succesful login after 24 hours have passed from thier last growth.
  • They can grow in Backpacks, Banks, and beetles, and sub-bags within these.
Techniques for Backpack plants:
You can organise them if you want, in a bag.
But i would recommend organising them in bags per color/type instead, And use the UO-Assist Use-once Agent: (remember to set a key to trigger it)
Magincia Growing
To plant a plant in magincia you need a Hoe Image which is purchaseable in magincia north west area. in a small complex thing from "XXX the Gardener" are 2 of them.
To plant a plant in the nature of New Magincia, use the hoe on the ground. Then a seed in the patch of dirt the hoe made on the ground.
You can only plant one plant in magincia per 4 days, per char.
This will grow on server up.
You may also use the blue "Crystelized essence" to speed up the growth.
For explanation on the plant gump and more detailed information on seeds and stuff, you can visit the stratics guide: Here
Users browsing this forum: No registered users and 2 guests
[ Time : 0.010s | 17 Queries | GZIP : On ]
