View unanswered posts | View active topics It is currently 14 Nov 2026, 21:43
 Post subject: Imbuing Calc Update
PostPosted: 16 Jul 2012, 14:26
Greetings All
I'm proud to announce that our Imbuing Calculator, which we consider the leading web-based of the kind, Just Got Better!.
100% Accurate
We have fixed the known issues and the Imbuing Calculator should now 100% reflect in-game results.
Weapon Speeds & Armor Types
To do that we added weapon speed selection for weapons, and armor types selections for armor.
Custom Mode
We also added a custom mode option, that, when enabled, will allow you to take intensities above the imbue-able cap. This can be useful in imbuing ecru rings or other items, where an intensity is already on the item which is above the cap.
On the (also new) popup with print friendly contents, as well as on the calculator it self, will only show materials used for stats that are imbueable.
Whetstone Compatible
There is now an option to apply a whetstone, thus removing di from an exceptional item. You can undo this also.
Thanks for your continued support!
-The Knuckleheads
 Post subject: Re: Imbuing Calc Update
PostPosted: 16 Jul 2012, 14:52
Its awesome! :)
PostPosted: 17 Jul 2012, 22:42
Resolved an error with Mana and Life leech max values being incorrect in some cases, should now show correct 100%.
Users browsing this forum: No registered users and 76 guests
[ Time : 0.014s | 17 Queries | GZIP : On ]
